Engine Hour meter
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
Any recommendation for an after market engine hour meter that i can use with my Volvo Penta 2040 engine. Either digital or analougue.
<hr width=100% size=1>/forums/images/icons/wink.gif <font color=blue> Regards Andy </font color=blue>
dickh
8 Feb 2002
Suffolk
Look on eBay - try the seller:- lowtension.ltd who has a lot of VDO gauges at good prices
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
Rick
15 Jun 2004
Queensland, Australia
Re: Other uses for meter
One trick I've heard is to install another hour meter if you have an automatic bilge pump - that way when you go back to the boat, you'll know if it's developed a majpr leak.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
I've put a Lascar digital one in from Radio Spares - stock # 365-6274
It gives total time and a resetable time, which I zero when I fill up with fuel.
Jools_of_Top_Cat
16 Dec 2002
Given the chance again I would try for an analogue one. I have two timers, one on each engine. The Starboard timer recently reset for no apparent reason, luckily I knew the hours and as we speak it is counting away merrily. I do not know what re-set it. There is a reset pin on the rear (not all of them have this). Thing is I have not been near it to knock it or short the pin accidentally.
The analogue ones look nicer too. here
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>
</A>
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
Thanks Nigel. Thats what I'm looking for, Is it easy to install ? I assume straight on to the Alternator W terminal.
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
Thanx for the info topcat. I had also been considering the analouge but the ones I had found were quite bulky. Will have a better look on the RS website. Assume with the curtis one again wired easily off the alternator, and the amps are very minimal.
Jools_of_Top_Cat
16 Dec 2002
With the curtis hour meter I have just taken the positive feed from the ignition barrel.
There are four pins
+12v
-12v (these two to battery and battery switch)
+12v (feed to turn timer on)
and reset (touch it with +12v and it will set back to zero)
The unit is supposed to hold the data for 20,000 hours without power or something like that. Like I said I do not know how it reset, maybe it was me, a mystery.
Otherwise they have been working fine for me, the port timer never glitching.
</A>
joe17
10 Jul 2002
Helsinki, Finland
www.kolumbus.fi
Would these work on an outboard?
I was thinking of putting an hour meter on the charging output from my Yamaha 8HP outboard. Anyone know if it would work?
Thanks.
