Engine failure
Yealm
13 Apr 2017
Engine stopped suddenly yesterday with alarm going off and smoke and fumes. Chucked the anchor over and waited to be rescued.
Found the exhaust had ruptured!
Beta 25, fitted new about 3 years old.
Was wondering if this is a factory part or something modified to fit the boat? And why it should go?
(sorry upside down images!)
Tranona
10 Nov 2007
That is the highrise manifold and by the looks of it has been cut and welded because it was too "high" to fit under the cockpit sole (probably).
doug748
1 Oct 2002
UK. South West.
Mine went in a similar place after about 15 years which I thought was about par for the part. There was evidence of internal corrosion
I agree, it looks as if two cuts have been made in the bend and re-welded but that may not explain the failure. The exhaust hose is rigid stuff and if one end, of a short run, is held rigid it may well stress the failed area. I loosened the mountings of my water trap to help in this respect.
After such a short time I am sure Beta will give a good deal on a replacement - should be c£200 or less. It might just be worth speaking to Phoenix 316 in Plymouth to get a price for having one made up.
Will post a photo of my old one when I find it.
Yealm
13 Apr 2017
Many thanks! It’s being re-welded today. Will replace it over the Winter.
Wondering if the main issue is a botched weld or due to some vibration/shaking ?
Sail Away
2 Sep 2010
Snap!
Beta 25 exhaust elbow, engine new in 2017, 700 running hours.
Picked a particularly bad moment to fail, while trying to berth in small marina in strong winds, lots of revs needed. Once berthed, found engine bay and bilge completely flooded. Took a full day to cleanup, not good!
After the event, did notice some staining under the lagging fitted around the elbow, so it had been failing for some time. Had the elbow re-welded and this time didn't take the lagging over the joint that failed. Hopefully easier to spot a problem in the future.
Have now heard of a few similar problems with Beta high-rise exhaust elbows. The failed weld is subject to high thermal stresses, as it is just above the water injection point, so a large temperature difference across the weld. So thermal cycling and internal corrosion due the exhaust fumes, eventually resulting in failure. I think I may get the elbow re-built with the weld moved further away from the water injection sleeve. This should reduce the thermal stress in the weld.
Lesson learned, checked the exhaust elbow regularly!
Yealm
13 Apr 2017
Very interesting!
I wonder how useful checking is- whether likely to be visible signs prior to rupture?
DownWest
25 Dec 2007
S.W. France
While the OPs was modded to fit, that is not where it failed. A call to Beta would be in order... Frequent inspections would probably show the crack starting, but you would have to look closely.
doug748
1 Oct 2002
UK. South West.
Very interesting!
Mine did not fail I found it cracked when I took it off for a de-coke check. Mind you it was shot, I opened the crack by hand and it fell apart. I don't think it would have lasted more than a few hours, I was just lucky.
Yealm
13 Apr 2017
Gosh, that's 3 of us !
Inherent vulnerability of exhausts in general, or a specific design/manufacturing defect?
capnsensible
15 Mar 2007
Atlantic
When delivering yachts, the engine exhaust is always something I give as best a looking at as I can. Including a good old shake. Not perfect by any means, but at the very least one gets familiar with the pipe run and access.
On my own yacht I carried plenty of JB Weld and decent size jubilee clips. A patch cut out of a food tin plus those items got me out of bother once.
Sail Away
2 Sep 2010
Very interesting!
Welds rarely fail suddenly, much more likely to be a progressive failure over time. In my case, the brown staining you can see around the failed joint was a warning sign. Unfortunately the lagging I had wrapped over that area obscured this. Did not look close enough. Friend with a Beta 43 and same high rise elbow spotted a pinhole crack in the weld, luckily well before complete failure. Again only a few years old.
So I would say yes, regular careful inspection should pick up a problem. Using dye penetrant crack detector spray would be even better.
Also agree with other posters, weld penetration is not good and this won't have helped.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
I love my newish Beta 25 with its high rise exhaust. However I will be checking its fidelity in future to guard against unexpected partings!
Has anyone contacted Beta about this matter as failure after so few years suggests some kind of manufacturing deficiency
