petem
I assume at some point VP will discontinue the supply of ECU's. Does anyone know when tis is likely to be for KAD44's for example and what the workaround would be if one fails?
I'm sure that Vas could knock up an ECU with £50 worth of Arduinos so I like to think that some enterprising company will manufacture functional equivalents when the time comes. I guess they'll need to reverse engineer the code / maps / config though unless VP open source it.
I'm sure he could. £500 to his customer base though.............![]()
In the case of this generation ECU you will achieve nothing when you pop the lid off because the whole board is encased in a silicon like gel , the make up of it is nothing like a car or computer board . Believe me I’ve tried many companies to lol at them , no one recognise it . The system was built and designed by Niro Automotive, I also tried to contact them direct to get a repair.Arduino won't work - its not a real time device. You'll be trundling along at 20 knots when it decides to do some housekeeping function in the processor and you'll fall off the plane.
VP will be forced into obsoleting the part at some point by the fast moving electronics components market. Grey market and last time buys of obsolete surface mounts, BGA's etc won't last for ever. Even Volvo with their buying power would not have leverage on that industry to commission components.
Aftermarket ECU is viable, its just a real-time computer with half a dozen inputs, half a dozen outputs and some data in tables. There might even be an open source solution for those wanting to mess about. Getting the various data tables right to deliver power and protect the engine would require skill and combustion knowledge.
ECU repairs firms in the back of Exchange and Mart do not have the equipment to emulate the ECU working, all they can do is pop the lid off and look for cracked solder joints, damaged tracks or damaged components and replace them with similar. Its pretty low level/barn door approach.
The units are produced as blanks then programmed individual at Volvo to each engine map as a dedicated part number .
