Engine Dilema - Perkins 4.236
coopec
N/A
23 Nov 2013
This really is a non issue for sailboat motors. Most people if using their motor will load it well. a cruising speed of a 9-11m yacht with an engine in the 20-40hp range will cruise between 5-6.5 knots which will require 50%+ of maximum load and usually higher, particularly with smaller engines. The issue with generators is well known, but is not transferable to yacht use. As I suggested earlier the only situation where you might get long term light load running is using the engine to "top up" sailing speed, but this is not common.
My last post on this thread! (A very busy day ahead!)
What about using the diesel auxiliary to charge the house bank? Is that OK?
Tranona
10 Nov 2007
No - already mentioned this in an earlier post - although in reality the few hours that people are likely to do this probably won't result in any serious damage.
You have to remember that the vast majority of yacht engines do around 100 hours a year and rarely actually wear out. They die from underuse and neglect and it usually the bits in contact with salt water that fail rather than the basic mechanics of the engine.
coopec
N/A
23 Nov 2013
Yes I just saw your mention of charging batteries with the auxiliary(y)
We have to motor 50km from A to B. Should we travel at hull speed (90% load) or motor at 5knts (40% load)?
AND this time I am going.......:cool:
jdc
1 Dec 2007
Falmouth
While I have the greatest of respect for Vyv Cox, his paper (which I am thoroughly familiar with) is not an academic one, cites no experimental evidence and is not peer reviewed. Google search shows most articles link back to his as a source, which speaks volumes for his authority rather but is not additional evidence.
dankilb
23 Jan 2008
Indeed - ‘Google and take your pick’ is not quite the advice I’d give in response your request for peer reviewed evidence!
Beneteau381
19 Nov 2019
I would have thought that bore glazing and gumming up of piston rings WOULD cause loss of compression....
The point I am making is that the words used imply that light running causes low compression in the cylinder whilst it is running at that point in time. Therefore my comment about poor translation.
Beneteau381
19 Nov 2019
Oh dear me.
