blackbeard
for, in this case, a Yanmar 1GM.
I finally succeeded in dismantling the through-hull/seacock/strainer in my boat. The seacock had begun to weep a little around its spindle and the plywood pad associated with the through-hull looked a bit sad. Other than that, there was no sign of trouble, no visible corrosion and no suspicious pink patches. The through-hull had a sort of coarse sieve around the intake to keep rubbish out, although this also made it more difficult to remove flora and fauna which had taken up residence.
So I could just replace the seacock with one of similar design - the original had given about 18 years of good service and a replacement would not be expensive - and replace the little plywood pad (with some decent marine ply this time, maybe even with a coat or two of primer), give everything else a good clean-up and a close inspection, and reassemble. But before I do this, I seek the collective wisdom of this forum:
Should I replace the through-hull, just to be sure? if I do, should it be with one of the same type? This would be the most cost-effective solution, and presumable what the boat-builder thought best. Do I need the external strainer, or should I have just a hole as normally seems to be done (but it seems to me to invite a blockage)? Given that the original shows no sign of corrosion, is there any point in using materials other than corrosion-resistant brass?
There seems to be a white material in the threads where the various components mated. I take this to be some sort of plumbing compound (Boss-white or similar). Is this recommended?
Should there be an electrical bond between through-hull and hull anode (there was originally)?
