lpdsn
Have you ever quantified the performance loss? If so, how?
The point I made earlier is that you may be able to notice it against another boat in a one to one situation (assuming you can control all the other variables) but on a passage would not make any difference that you could tie down specifically to that.
I have spent a few minutes earlier today trying to find something a bit more definite on the drag of the lines of the lazyjacks but haven't found anything beyond a basic theoretical calculation for a cylinder. I know there was work done based on a conversation with someone who did wind tunnel tests - more in the context of the effect of halyards tied to the toe rail rather than base of the mast, where he said he found the drag of a line was quite significant - but I suspect that was just a final year project. I really wanted to find something empirically based as the surface friction will have a significant effect hence rejecting the theoretical approach. Anyway I don't believe the effect to be trivial.
You only have to sail in a one design fleet for a while to see how much difference boat preparation and a reasonable attention to detail makes. OK it pales besides being unable to trim or steer properly but all these things are accumulative so you can't assume just because you've accepted a hit in one area accepting a hit in another will have no effect. The spread in a one design fleet never ceases to amaze me.
Of course there's always the old argument that it's cruising so it doesn't matter when we get there, but that's personal preference and I'd rather not spend another couple of hours on passage at the end of a long day beating against the tide when I could already have been there before it turned. Others can take the opposite view, or even just decide not to make that particular passage on that day - there are certainly cruising grounds where that choice is easy.
It really is close hauled where the useful force derived from the lift doesn't have a big margin over the drag where unnecessary extra drag has a noticeable effect. A bit of extra drag when beam reaching just doesn't have the same effect.
