JumbleDuck
That's interesting. I've a copy of CA Marchaj's Sail Performance. At one point when discussing laminar and turbulent flow in the boundary layer of sails and the effect of surface roughness he goes on to discuss the effects of localised roughness. In that he concludes that there is a larger detrimental effect from roughness near the leading edge than near the trailing edge. If you can beg, borrow or steal a copy it is on page 101 (Chpt 6) with the accompanying Fig 83. I've the 2003 edition.
In terms of keels and rudders on racers the usual practice when fairing is to put (even) more effort into the foils than the hull and the put even more effort than that into the leading edge and first third of the foil as in most conditions laminar flow beyond that is unlikely. Also to make the trailing edge cut off of the keel assymetric (although I've heard various explanations of that last point).
PS I realise CA Marchaj's work is quite old - I have more recent books but his is the easiest to skim read to find the bit I was looking for.
Thanks. I'll have to track down a copy. The concentration on the first third of foils may (also) be because - roughly speaking - the centre of lift is generally about 1/3 of the way back, so the first 1/3 of the foil generates ~2 times as much lift per unit length as the back 2/3 and is therefore ~2 times as much worth getting right.
