GrahamM376
yes, but then you add the important caveat that if you suspect a person to be significantly compromised by respiratory disease then you will only allow them somewhat less than 15 l/min; shouldn't your starting point here be that if their lungs are shot then go straight for 25 l/min?
my point is that, on board a boat, it is safe to administer oxygen without monitoring or training. if either of those are available to you then so much the better as the lowest flow rate possible is essential to conserve supplies. if the op uses his chemistry set then even this isn't a consideration as it is of fixed flow rate and duration.(and, at £250 i would be reluctant to crack it open in the first place).
Maybe treatments & knowledge have changed over the 20+ years since I was involved with oxygen in rest home situation but, the instructions we received then was that there was a danger of giving too much to someone with emphysema, in that it could kill because the brain monitored oxygen rather than CO2 levels, whereas those sufferning from acute bronchitis or asthma could, and did, recive higher flow rates.
