KompetentKrew
After multiple emails exchanged with B&G's support over a couple of days, they still hadn't given me much in the way of technical details and I finally googled what port to use - I agree with @stevead on CruisersForum when he says "B&G do themselves a disservice with their lack of good technical documentation."Thread resurrection time as I get closer to purchase.
I was reading the Navionics guide to how to connect AIS, and it offered an option I hadn't previously considered - using a WiFi-enabled chart plotter like my B&G Vulcan 7 to provide the WiFi feed to the Navionics app. That would mean I don't need a WiFi-enabled AIS, which is quite a saving in Emtrak world.
Has anyone used this option?
What B&G did tell me is that "Vulcan will transmit all NMEA0183 sentences listed in the manual and AIS data" - that is to say all the supported NMEA0183 around pages 62 & 65 of the manual - and also that data present on the NMEA2000 network (wind, speed, depth are mentioned) will be converted to NMEA0183 to be transmitted.
I don't yet have AIS installed on my boat, but I tested the Vulcan with OpenCPN and it seems to work - certainly the GPS position is transmitted, so I assume the rest is ok. Connect a laptop to the Vulcan's wifi and go to "Connections" in OpenCPN's preferences to click "Add Connection" - make it a network connection, TCP protocol, and enter the Vulcan's IP address (which is the wifi gateway you're connected to, or can be found in the Vulcan's wifi settings) and port 10110.
This may have saved me the cost of the premium em-trac model - I'll read the manual this weekend and see if it has any other features I need.
