Elephants Ear on a Bun
Bigplumbs
7 Nov 2015
UK
Do you ever feel that you are looking for something quite simple but cant find it or know what it is called.
I have removed the old heavy fiberglass housing for the old (Broken) chart plotter from my Sealine S24 and fitted a new garmin. In the dash there is a hole about 50 mm dia that I would like to cover but also let the wires come out.
I am looking for what I would describe as a white plastic domed cable outlet with a flange so I can screw fix it to the dash all about 75mm ish dia.
I have searched for ages and remembered a line in Faulty Towers where the chap said it wasn't as if he was asking for an Elephants ear on a bun.
Anyone any ideas if not I will have to make one
Dennis
https://www.force4.co.uk/index-marine-deck-gland-dg50a.html
84mm diameter
Thanks for the suggestions but none are really what I need. I did turn up most of those in my search.
I will keep looking
Dennis
If that is the sort of thing you are after you may want to consider a "deck side entry gland". No real difference except it's water tight and arguably may look better in situ.
