lw395
The current in a lightning strike doesn't really follow Ohm's law. It will probably favour travelling through the shrouds as they appear to be 'outside' the mast."Some people advocate trailing a stout wire or even chain from the shrouds to the sea. It probably needs to be stout though. This hopefully takes any discharge straight past your electronics keeping electric fields in the boat low."
It would be far better to connect wire or chain to the (ali) mast than rigging wire. The rigging wire is of such a electrical resistance that it will conduct some current but get very hot either melting or losing its temper. So subsequently likely to fail under strain. The mast on the other hand is very low electrical resistance so hopefully will dissipate power unscathed.
If it does go through the mast, what's going to happen at deck level?
