[70521]
Just to add... I considered WiFi/Bluetooth connected kit, but quickly discounted it as I considered there was a higher risk of failure.
While I'd be swearing (again!), I do have some sympathy for that point of view.they had gelded its functionality because they were worried about the skippers 10 year old in one of the cabins taking over the pilot contol.
MInd you the B&G wifi gadget was a waste of time - they had gelded its functionality because they were worried about the skippers 10 year old in one of the cabins taking over the pilot contol.
AFAIK there isn’t an interface currently that allows wireless connection between makes of marine instrument. Any connections - e.g between a Raymarine wireless radome or a NASA wireless masthead wind - would still need to go through NMEA 2k backbone to sync with, say, a B&G plotter (and even then, presumably the radar would only connect wirelessly with a Raymarine plotter?).For me the attraction of wireless is the ability to easily connect kit of different makes. My last boat had an MFD from B&G, Raymarine ST instruments, simrad / robertson pilot and I cant remember the ais maker. It was a nightmare to get talking to each other and needed a multiplexer because the Raymarine was the original ST, the pilot was 0183, the radar was ethernet, and the ais was 2000.
I’d fit one on each bulkhead either side of the companionway on a tiller steered yacht or on a smaller one have it on a swinging bracket to swing out of the companionway. A dim, waterproof but non buoyant tablet that goes flat is a suboptimal solution.FYI: there are robust, waterproof tablets on the market.
Also, my boat is tiller steered - so, no pedestal to mount the plotter.
Mounting it under the sprayhood or on the bulkhead would mean the plotter would be too far away from the tiller to be of any use to me.
You have two tablets to mitigate a sub optimal solution.1. Why would a tablet need to be buoyant?
2. I carry two. So, when I get a low battery alarm, I use the other one whilst the first one recharges.
3. Two tablets are (a lot) cheaper than two plotters.
4. Another reason to have the plotter down below is this: I plan my passage on a paper chart, then I transfer my route/waypoints to the plotter which is the hub on my network (linked to all instruments on deck and the autopilot).
It's a lot more comfortable to do this from the chart table down below than it would be to have to do this in the cockpit (regardless of the weather).
Having a purpose built plotter inside the boat is a waste. It belongs in view of the helmsman. The benefits for pilotage in particular are immense. The benefits of AIS in poor vis is immense. And if you have a radar all that x10.
The tablet is better for transferring routes than the plotter as you can place it on the chart rather than poking a thing on the wall. You can quickly type in route and waypoint names.
And even if you still rely on the anachronism that is a chart table, you can take the chart and the tablet to the dining table to do the transfer - because the dining table is bigger and better. Yes you can do that if you plotter is inside but you used the transfer as a reason for the plotter being inside. It isn’t a reason.
Agree with this. Sailing singlehanded I find the ability to instantly engage a good autopilot is the single most valuable item. Depthsounder and speed next. Navionics is remarkably good. Ability to get GPS position is useful.I have had boats with: a) no electronics at all, just log and depth b) wireless instruments (TacTick) c) Chaplotter at helm, d) chartplotter at chart table. What I found in all cases was that I actually used were various handheld devices most of the time (iphone and iPads in my case). They are just so much easier and convenient to use.
So on my latest boat where I actually had a choice I have:
Raymarine EV200 Autopilot (plus backup with original Autohelm), Raymarine depth and wind, Em-Trak AIS, and an Actisense NMEA 2000 wifi gateway to get it all talking and displaying speed, depth, wind, AIS etc to a couple of IPads and iPhones, plus those of anybody else on board. Apps display both vector and raster charts plus all the usual functions of a chartplotter with multiple backups. I also have a Furuno wireless radar - again is fine for my main use of radar (picking up squalls) and cost under £1,000 unlike other brands. This displays on an ipad app and overlays on a Vector chart through TZIBoat.
All worked seamlessly on a 4,000-mile trip to Portugal/Spain and back with multiple stops - and so far haven’t managed to drop the ipad over the side. I can also use the ipad for an anchor alarm that I can leave on the boat while having a copy with me on my phone, writing posts to this forum and watching films, which most fixed chartplotters can’t manage yet. In bright sunshine I move to the shade of the sprayhood. I sail both single-handed (with dog) and with crew.
As someone else said, it’s horses for courses and this works for me - and is a lot cheaper.
I think the risk with all electronics is that you can start looking to them first rather than watching the sea.
I have witnessed some chaotic excitement with people entering way points, trying to identify buoys and generally becoming immersed in technology when a glance at the (paper) chart, some prepared headings and bearings and a good look around outside provided a safe and simple passage.
Per my post #11, I believe danklib and I concur on this one. There's a defacto (non-) standard that's been adopted by most wifi applications (OpenCPN, Navionics, iNavX etc.) but while some plotters will transmit data in that format (e.g. Navico plotters via their GoFree access point thingy), I'm not aware of plotters from the mainstream manufacturers *receiving* data in that way, nor of instruments which transmit their data like that (ie nmea-0183-over-IPv4-over-802.11 as opposed to proprietary radio formats).
