Kurrawong_Kid
When my boat was recently lifted for mid season scrub, it was noticed that the stripper had dropped off the P bracket and where it had been there was significant corrosion. In addition the main anode had worn away considerably and the shaft anodes less so. The boat was launched in February with two shore power heaters on a time clock. In previous years I have done the same with no corrosion noted,
I have made 2 modifications since launching. I have fitted a water tank (12v.) gauge of the impedance type (from Force 4) and extended a 240v. ring main. Gould either of these have set off the corrosion?
Or might it be from "hot" water in the marina?
The boat is fitted with a sterling battery charger and sterling galvanic isolator. Any advice on how to start to track down the source of the corrosion would be very welcome.
