Forty_Two
This is what i am referring to from the manual:Looks like you might be getting confused with centre tapped inverters, which the Victron is not.
It is, however, possible that the inverter has been incorrectly installed. Once the fault is found, the inverter installation must be checked. Once again though, i'd want to know how/where the immersion is connected
The MultiPlus is provided with a ground relay (relay H, see appendix B) that automatically connects the Neutral output to the chassis if no external AC supply is available. If an external AC supply is provided, the ground relay H will open before the input safety relay closes. This ensures the correct operation of an earth leakage circuit breaker that is connected to the output."
