Electrical question...
Captain Crisp
1 Mar 2015
I've just installed a Seaflow auto bilge that runs for a second every 2. 5 minutes... Assuming the bilge is dry, it would run for about an hour in total per week...
It draws12 volts 2.5 Amps...
How long before my battery is flat?
(failed my Maths A Level for context)
Relevant pics below (wiring is work in progress)
Thanks!
Aeolus
3 Aug 2004
Sussex
If you've a single 80Ah battery, then 16 hours of bilge pump operation would use 50% of your battery capacity. It may damage the battery if you allow it to go lower than that. At 1 hour operation per week, you have approx 4 months by my reckoning.
ylop
10 Oct 2016
That would drive me mad. Far too complicated, makes a noise every minute, plus it flattens your batteries. 😳
Float switches can jam / fail.
Float switches may take up space in tight places.
Float switches often leave more water in bilge than these.
So, for some applications, some people prefer them. They aren’t new so presumably enough people buy them to make it a viable product line.
Sticky Fingers
21 Feb 2004
That’s all true, the jam/fail argument seems to be counteracted by the increase in complexity of the alternative IMHO.
Unfortunately there's no room for a float switch and pump in the bilge sump, the good news is I can turn it off, when I'm on board.
Fair enough 👍🏻
billskip
6 Sep 2001
Well the "one second" would have a high kick in spike and a low run demand ( not under load) which I would think to be less than 2.5amp demand per second, taking all other possible losses (theory against practice) I made a guesstimate time.
Irish Rover
5 Feb 2017
Türkiye
I have one of these in my tender - I posted a thread about it last year. They have to be the most stupid design of a bilge pump ever. I haven't got around to replacing it yet, so I had to disconnect a battery terminal to stop it discharging the battery over the winter when I rarely use the tender.
Poignard
23 Jul 2005
South London
As the OP has installed the pump, he isn't likely to get a refund if he tried to return it.
To prevent it cycling on and off continually, perhaps a 12v float switch could be wired into the pump supply so that it only becomes active when there is a certain level of water in the bilge sump*.
*The Twister has a deep bilge sump about the size of a shoe box below the front of the engine into which the float switch could be fitted.
Captain Crisp
1 Mar 2015
There's not enough room in my sump for a pump and a switch... I've reassembled all the stern gear stuff, so hopefully all this will be purely academic... Also, French's have said they'll repair my prop for £85!
Now for the blinking woodwork....................
