hunter323
I am a novice as far as electrics are concerned!! I have a twin battery system monitored by a NASA battery monitor and the usual switch with off 1 1+2 and 2. When I turn the switch to on, the monitor shows a discharge climbing to 3.6amps although as far as I can see everything is turned off although there a few items serviced directly from the batteries. I also have a solar panel and wind generator which appear to be working correctly as when the switch is off the monitor shows a charge of 0.2amps.
Any suggestions as to how to track the problem and solve would be very gratefully received.
Is boating all about solving 2 problems only to get a new one!!!
