petergarth
I'm busy reinstalling my Volvo Penta 2002 after a rebuild and posted several times.
Going reasonably well but all of a sudden an unrelated problem.
I'd re connected the electrics to the engine and switched on the DB.
I have two main battery switches, one for each battery bank (house and engine) but won't go into detail on this.
All fine (listernin g to music while making progress) when suddenly all power goes down.
NO voltage at the starter motor circuit and no power at the DB.
I trace the power from batteries through earth leakage etc etc. all the way but at the board no power.
After disconnecting +ve to starter motor (thinking this might be a problem), no change.
Then I notice I have power at the DB.......BUT it's only about 2.5 volts. Just enough to like a few CB LEDs.
Battery banks both showing full charge, solar panel working, all good!
Switch off all circuit breakers at the board. Switch off battery and DB main switches.
Switch back on and power at the board shows normal ( same voltage as measured at the MPPT on the solar panel)
Now here is the baffling bit.
As soon as I turn on ANY one of the circuit breakers at the DB, the voltage immediately drops back to around 2.5 to 5 volts.
If I replay the procedure it happens each time.
As soon as I switch one a CB the voltage drops.
What can be doing this???
I am stumped.
Any ideas from the forum experts will be greatly appreciated.
I am stumped.
