Electrical Failure.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
In the middle of Poole bay on Saturday the gps keep dropping out, and when I had re-started it a few times the autohelm started setting itself to standby. Also the vhf screen went blank whenever I tried to transmit at 25W and nobody seemed to be able to hear me. Then the instruments went crazy with a mass of bleeps and the ST60 voltmeter swinging up and down between 12V and 15V. Suspected the voltage regulator as the engine was running, but when I checked the voltage at the battery terminals it was a steady 14.5V. So shut down all the electronics and carried on with handheld gps, handheld vhf and handheld tiller.
Next morning in Weymouth I found that the negative cable from the main panel to the earth on the back of the engine was broken. It had been sharing a large crimped terminal with the main battery negative cable and had broken where the two cables met. Easily fixed but it gave me pause for thought; all those modern electronic aids let down by a 23-year-old bit of copper about 4mm across. Just glad it didn't happen in the middle of the night in the middle of the channel!
at least you learned to navigate without all that stuff. Imagine what it would be like for some of the newcomers who haven't known it any other way. "Wot's an EP?", or worse "mayday my GPS is broken"
