mikewade
Active Member
I have spent some time googling but haven't found a full answer so I wonder if the panel can point me in the right direction.
My boat is a steel van de stadt 34, 20 years old and I have just rewired the 12v side.
I note that presently the 240Vac installed seems to be twin core & no earth and so I want to start repacing the 240vAC side using an RCD and galvanic isolator & three core cable.
I use shore power if available for short bursts of battery charging if she sits for a couple of weeks & through the winter will use a dehumidifier.My question is simply what do I earth the new AC supply to as it appears that earthing to the hull is a no-no! is this correct?
Is this a problem in a steel boat? my knowledge of electrics is less than zero so any help will be gratefully received.
