dignity
I need to do a bit of welding on my boat, I'm a bit unsure whether or not I need to disconnect everying electrical i.e. starter-motor / alternator, is it a case of just taking the earth connection off, or should they be totally removed to avoid damage when welding.
Also the shore-power isn't good enough to run my welder, can anyone forsee a problem if I use my onboard generator (which is totally isolated from my hull)?
Any thoughts would be gratefully received before I fry my electrics!
