TonyMills
I am using a small electric trailer winch on a temporary fordeck base to raise the mast after I go under bridges in Fremantle. The winch is new and theoritically has a single line pull rate of 900 kilos. It is wired through to the battery using crocodile clips and this wire is about 6metres long. and I run the engine during operation.
I find that the pull rate is much slower than expected and I usualy give up and pull it up with a three sheeve block and tackle which is attached just in case.
Could this be because of the length of the wiring between the winch and the battery? Or is the idea not viable because cheap trailer winches are not strong enough for the levered weight when raising a mast fitted with a spinnaker pole 'A' frame on a 30ft boat?
