Electric outboards for tender (budget, not Torqeedo) - your experiences please
That's if you go lead-acid. The Outboards Which Must Not Be Mentioned (TOWMNBM) use Li-ion batteries, which explains their insanely high prices (their batteries include GPS receivers, for some reason, which can't help). Prices are coming down, though - http://www.amazon.co.uk/LI20-12-LITHIUM-MOBILITY-ELECTRIC-VEHICLES/dp/B00SJB5XSG is a 12V, 20Ah Li-ion battery for £190 delivered. It only weighs 3kg and will give you 20 minutes of full thrust on a Minn-kota 55lb model. Still expensive, of course, but I don't think TOWMNBM are going to have the market to themselves for long
12V 20Ah
That's 14,400 Watt-minutes.
I was on a rowing machine the other day, which gave a readout in watts. Unfortunately, I can't remember how many watts I generated.
but I think that's equivalent to a pretty hard rowing session for a middle-aged civilian?
Maybe there's a market for onboard rowing machines to recharge the batteries?
...Prices are coming down, though - http://www.amazon.co.uk/LI20-12-LITHIUM-MOBILITY-ELECTRIC-VEHICLES/dp/B00SJB5XSG is a 12V, 20Ah Li-ion battery for £190 delivered. It only weighs 3kg and will give you 20 minutes of full thrust on a Minn-kota 55lb model. Still expensive, of course, but I don't think TOWMNBM are going to have the market to themselves for long
Looks like the battery to have, if 'a little' expensive. Am I right in saying a Li-ion battery can be used till completely flat without damaging it?
Edit: Here's a 20Ah Li-ion for £150 delivered, although it is also described as 17Ah to 22Ah for some reason.
Yes, just about, and they maintain a good terminal voltage till almost the bitter end. That battery works out at £10 per usable Ah which is way less than the first Mastervolt ones for boats which were, as I recall, around £25 per usable Ah. Still a long way above lead-acid (£2 per usable Ah, if that) but heading in the right direction.
I have an old 1.5HP "Die Hard" trolling motor I was given when we lived in the US. Never been used before I attached it to Drifter's little 2.4m inflatable tender last year. Coupled to a 32Ah gel battery. It pushes the little dink around about as fast as I could row it with 2 people aboard. I find it fine for in-harbour conditions, and the big plus is that I can lift either of the 2 separate components over my head with one hand. I did some tests on battery draw-down and I think I got about 1 hour of 75% drive before there was appreciable battery voltage drop. So, I would say that they're viable propulsion for short-ish trips but I wouldn't want to use them on a heavier dinghy or in tough conditions (including fast tide).
I don't know if the Die Hard is a salt water motor or not. The paint is starting to flake off, but it's still working (touch wood). If it does conk I think I would be tempted to get a more powerful (non-Torqeedo) version.
I only use my outboard if I'm going a reasonable distance as I can get out to my mooring in less than 10 mins. As I always carry oars, I prefer to use them rather than mess around with engines. It's also a bit of a trek from my parking space to my dinghy mooring over a field so that's another reason to leave the motor on the boat at all times.
The notional Ah capacity is quoted at the 20 hour rate, I believe. What would the capacity be at the 20 minute rate?
Dunno, I'm afraid. my gut feeling is that Li-ion is probably less affected by discharge rate.
Then why not just use oars?
All a resolute non-user of outboards on my dinghy, this is a good question but one which I am not qualified to answer. Nevertheless, observation shows that many people prefer to use outboards for short trips by dinghy.
Yes, even when I earned my living promoting and selling outboards to such people I could never understand it.
I paddle my Canadian canoe to my mooring, and love paddling a canoe so thats no hardship. I guess the only reason I want an outboard is for using the inflatable in windy conditions (canoe usually left tied to mooring). Rowing a flubber with the wind up is bit of a chore - they skit around all over the show in my limited experience.
Incidentally, I recently paddled my canoe next to my pal that was rowing a small fibreglass tender - you would be amazed at how slow rowing is compared to paddling. My mate's a good rower, and yet I found myself paddling at less than half the speed I normally would to keep to his pace. I'm always surprised how few canoes are used as tenders. I can get two adults and gear in my canoe. It weighs 23kg, and sails well (takes an oppie rig).
Think most people would consider a 100 yard range twice a day pretty limiting.
Of course these motors will move a dinghy slowly over short distances, but they are only a substitute for an outboard over a very limited range of capabilities. If you accept the limitations that's fine for you, but would suspect most people want more.
If I was limited to 100yards then I to would find this pretty limiting.
I use mine for getting to the boat, and messing around sometimes I row, sometimes I motor, sometimes I row and motor.
I get a lot more than 100 yards, I can mess around all day.
Perhaps all the discussion can be summarised in this way...
A Torqeedo or small Trolling motor will push a tender along.
The difference perhaps is that a Torqeedo is a substitute for a small petrol outboard motor whereas the Trolling motors are a substitute for a pair of oars.
Sod the lot of them, I want a sailing tender! :-)
I went to a talk by a couple who'd sailed a lot of Polynesia, they seriously reckoned a sailing tender was a godsend. No fuel to buy, no worries etc.
The time a tender is not nice to row tends to be when there's breeze to sail?
As I said upthread, we use a sailing tender. There wasn't much good sailing for it this summer, but it's great fun when the wind's right, and when the wind's wrong there are oars.
You can charge the Torqeedo battery directly from the ships battery, no need for an inverter. They sell a lead or make one, cigar plug direct to Torqeedo.
I know and have one, but (at the expense of power loss) an inverter with fast charger plugged in is very much faster to charge. I haven't tried to find to find out why.
