seajayare
On my boat I have 2x 6kW electric pod drives.(like a saildrive with the motor direct onto the prop). I usually use much less than 6kW so I can choose to run one motor at up to 6kW or both motors at 1/2 the the load each.
I have trying to work out if I am better off running one or both motors and if the props would be different in the one motor scenario over the 2 motor scenario.
I am pretty certain the props on the boat are the same as if I only had one motor and I am wondering if that is sensible.
(a 30 foot sail, about 6Te)
