SteveIOW
Have just fitted a Lewmar Pro Series 1000 Windlass. Have connected it up to 12 v battery supply, via Contactor and Circuit Breaker, with nice big 25 mm2 cables as recommended in Installation Manual. Have yet to fit the control circuit to the Contactor. This needs to be 3 core (common live + up and down). Manual does not say what cross section cables to use. A 3 amp fuse is required in the common live so I presume the current will be less than this. Am thinking of using 3 core domestic flex (not solid 2 core + earth). If this is OK what cross section cable should I use. Distance from Contactor to furthest control switch and back to Contactor will be about 14 metres.
