BigLes
Just bought a boat and it has an old Stowe echosonder. We are replacing it with a NASA Clipper, however the Clipper transponder is the type that is installed inside the hull and sounds out through the GRP hull. The old Stowe one protrudes through the hull.
Question - can the Clipper transponer be fitted through the hull, or is it better to fit the Clipper in a new position? Should I leave the old transponder in place, or remove it and make the hole good with GRP? If left in place will it affect the new transponder?
Thanks for any replies.
