Eberspatcher service
tjbrace
8 Mar 2007
West Mersea, UK
I have to rebuild my D4+ after a service. I think the machine screws holding the lumps of aluminium together are stainless steel and I see no sign of any Duralac compound on them.
Should I use something to stop them corroding together or does it get too hot for the available compounds.
TIA
Alex_Blackwood
19 May 2003
Fareham
TIA
If it hasn't been a problem in the past why should it be in the future? :unsure: Use what was on when you took them out! :)
tjbrace
8 Mar 2007
West Mersea, UK
Thank you gentlemen for your replies.
Norman, I’m not too happy using copper with aluminium, lots warnings regarding copper antifoul paint on aluminium so I will give that a miss.
Alex, I could see no sign of any compound being used previously so I shall do the same. It goes against the wisdom shown here in other threads though.
Thanks again. T.
NormanS
10 Nov 2008
Thanks again. T.
I wouldn't have thought that your Eberspacher would be subjected to salt water. 😕
Copaslip is primarily designed to aid the disassembly of metal object subjected to high temperature, but do what you think best.
There is/are Loctite products that are equally suitable.
Alex_Blackwood
19 May 2003
Fareham
+1 No reason why you should get either Galvanic or Electrolytic action on heater parts. You may have dissimilar metal but no electrolyte (Salt water). How old is it??
tjbrace
8 Mar 2007
West Mersea, UK
Eber. Is 13 years now.
I had aluminium window frames in my first boat, Vivacity 20’ these were ‘affected’ by brass fixings quite badly. I don’t remember a submersion just a very salty atmosphere.
Thanks again.
