rjp
I thought the Eber. threads needed a bit of a boost so here goes.
One minute it was going fine, next minute the blower was still turning at a moderate speed but there was no heat and it didn't shut down. The only way of stopping it was to kill the power by pulling the fuse, the rheostat controller had no effect at all. At the time this happened I didn't have the digital controller but have since fitted one and found out that the error code is AF:33 - speed deviation, which suggests a motor or controller problem. I've checked for obstructions in the ducting and found nothing.
Does anyone have experience of this problem? If I clear the error on the controller the eber. seems to begin it's normal startup sequence at low speed, then after less than a minute the blower speeds up a bit and stays there. No ignition takes place, no smoke, nothing. Great for ventilation but useless for heating.
It's still fitted in the boat at the moment, but I'm planning to take it out this weekend for a better look, so any suggestions gratefully received.
(It's a D1LCc by the way).
John
John
