mlthomas
Our eberspacher is making a noise, sounds like a dripping tap with around 3 to 4 drip sounds per second. When we switch it off and it goes into the cooling cycle the noise stops. Any ideas?
agree its the fuel pump..quite normal
...I should be able to mount the fuel pump on some rubber, but what about wrapping it in something first?
Fantastic, many thanks Andy I will have some of these ordered on Monday so should get the job done next weekend![]()
The pump sits in a P clamp which uses a 6 mm bolt, so buy the cotton reels with 6mm threadsNo problemIn case you haven't sussed it out, there are all sorts of thread sizes and lengths available to suit whatever bracket is on your pump.
Good luck.
Andy
Thanks all, sounds like it is the fuel pump. I’ll have to go and look for it to see what I can do. We have the two cabin oceanis and prefer the aft cabin. First really annoying noise was the battery charger that leaps into action every other minute or so, quickly fixed by turning it off (not rocket science, just took some figuring out what and where it was coming from) leaving this to sort.
Ours went very quiet when I mounted it on one of these
clicky
The pump is in the cockpit locker (as is the Eber.) and is almost inaudible when the locker is closed. It was previously direct mounted to a bulkhead and could be heard throughout the boat. I think you can get a rubber mounting bracket for the pump from Eber as well (if you haven't already got one).
Our pump has plastic fuel pipe running to & from it, too which must help reduce noise transmission.
The pump is definitely noisier if there's air in the fuel (e.g. small leak on the suction side or you're running low on fuel!!).
0.02p
Andy
