Eberspacher external temperature sensor question
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
Can anyone tell me what the specification is for this (on a D2 it connects to the grey wire and, I assume, ground)?
Presumably it's just an ordinary thermistor, but I want to know the manufacturer's (eg Siemens) spec (i.e ntc or ptc, and resistance at 0, 50 and 100C).
I bought a second hand D2 in good working order, but it assumes the use of return ducting, which I don't want to use, and so uses the internal sensor on the air intake to sense the temperature.
Rich_N
10 Sep 2013
I realise this is an old thread but have been searching and found:
http://uk.farnell.com/jsp/displayPr...337469|plid|&gclid=COX4spOHv7kCFfHKtAodjFwAkQ
This sensor appears to be identical to the Eberspacher original and may be used connected between the grey and brown/white wire when the internal sensor is disconnected on the D1LC and others.
They are less than £1...
Hope this helps someone else!
If assistance is needed with the wiring let me know.
