Ian_Edwards
Eynhallow has a Hydronic 10 fitted and I'm renewing the exhaust system. The reasons why will become obvious from the photos!
The original system had a very tight, and almost 180 deg bend in it, close to the skin fitting, to get the swan neck required to keep the water out.
I've bought a new inner exhaust pipe 500mm longer than the original so I don't have to make such a tight bend.
When I took the system apart, I found that part of the exhaust system has been reinforced with a larger diameter section of SS exhaust hose. This is a section which passes through a locker, so I guess it's to stop the exhaust hose from being crushed. I intend to reinstate the reinforced section. The ends of the reinforcement are sealed with a white sealant.
Does anyone know what this sealant might be?
Or what I could use in it's place?
The sealant will get hot, the exhaust is covered by an insulating sock and placed with a 60mm conduit, (the same types as you'd use as a hot air duct)
View attachment 48707View attachment 48708View attachment 48710View attachment 48709
