GHA
1000%!!!!!!!!!!!!! ?I decided *not* to make soft shackles out of anything other than HMWPE so as to avoid anyone accidentally using a weaker one in a high load application. HMWPE cost per shackle is low.
Haha the only one I have was made out of lazyjack rope. It's very cheap at £1/m vs £6.40/m but less strong 1100KG vs 4300KG. It's virtualy indistinguishable from Dyneema of the same silver colour and when I finished I thought exactly this, it's dangerous to have non-dyneema ones. I didn't want or need a soft shackle, I just wanted to try making one, but then I binned it!I decided *not* to make soft shackles out of anything other than HMWPE so as to avoid anyone accidentally using a weaker one in a high load application. HMWPE cost per shackle is low.
Far more importantly, it's based on a tapered bury. If you don't taper properly you may just as well tie a knot. Hownot2 showed this very nicely on YouTube, and the rope broke at the end of the bury without a taper at well below MBS.This is not to suggest skipping the bury is a good idea. Quite the opposite. There was a fatality on a Clipper RTW boat in part caused by the failure of an eye that was Brummel-only. The 72:1 rule is based on an effective lock PLUS a bury.
... If you don't taper properly you may just as well tie a knot....
My device won't access that page for some reason..
Works for me - try a different device.My device won't access that page for some reason..
I posted about the brummel lock eye and it is only since I received replies here and in another post that I have discovered people appear to be talking at cross purposes.
A brummel lock eye splice seems fine (thinwater states up to 45 % stength without stitching).
People jumped in and talked about stitching as if I had only mentioned an eye splice instead of of a brummel lock eye splice.
Am I correct?
Thinwater states stitching a brummel LOCK adds 5% strength.
For my needs it seems a brummel lock will not come loose 95% of the time.
The video in my post no. 1 seems to look rock solid.
I think I understand that stitching is 'mainly' for eye splices without the brummel lock.
Fair enough, but my confusion started after post 1 where I posted a link to a brummel locked splice :You added to the confusion by suggesting would we, I, bet my life on your work - with a 5% failure rate (for someone who has a few splices under their belt( - No. It might be fine for the application you were actually thinking of - but not for securing an individual.
Jonathan
" As in this video:
dyneema eye splice - Google Search
Is this eye 100% secure from slippage? It looks good to me.
I have been told to stitch the bury or stitch near the eye but is that necessary?"
This was followed up by talk of stitching.
STILL confused, but as far as I can deduce a LOCKED brummel eye splice is pretty secure without stitching? That was my original question. I would never under any circumstances (stitching or not) simply make an eye and bury 70% of the diameter and think it good enough.
So back to post one: is a brummel lock eye splice secure? The locking as per the video seems irrefutable.
I have a hydraulic press, perhaps I should test to destruction a brummel LOCK splice?
Bit late for me, but I was mesmerized that a brummel lock and simply burying the bitter end end seemed to provide a secure eye. WOW dyneema.
The thread then went on to stitching but a different thread about stitching said "why not use a brumnel lock?" Which made me do a double take.
I have no use or product in mind; I know dyneema is extremely strong.
I perhaps wondered if a BRUMNEL lock eye splice with no stitching was strong enough to support a 13 stone person assending a mast.
I would always prefer to lower a mast.
Just theoretically talking.
Some how the "brummel lock" in the title seems to have been overlooked perhaps?
Hence my confusion.
... as I can deduce a LOCKED brummel eye splice is pretty secure without stitching? ...
You could test to destruction - it would be an interesting piece of data
