roaringgirl
In 7 years and 10000nm:replace a chain plate with a soft shackle
But more seriously.
We have had Josepheline for slightly more than 20 years - before soft shackles had a mention. So the boat has lots of stainless shackles, Harken gear with matching shackles, Ronstan gear with matching shackles, shackles on sails from reputable sail makers, shackles supplied with the rig, a reputable mast builder - in 20 years one shackle has failed. have we been lucky? We raced our X-99 hard, JoXephine of Hong Kong, really hard (we have the glass ware to prove it), local club racing every weekend, RORC blue water races, 600nm - we did not break any shackles, but did lose 2 masts (tang failure). Have we been lucky?
What sort of shackle failure frequency have others had.
Jonathan
1. Snapshackle attaching mainsheet to boom tang opened while going downwind
2. Two stainless shackles holding the luff of the sail to the cars on the mast track worked loose. One fell overboard, the other's pin fell overboard. I only had one spare. They had been tightened with a shackle key at the start of the season.
3. Two shackle pins on mainsheet system worked loose - discovered during normal checks and retightened. This has happened 3 times. If I could replace them with soft shackles, I would!
4. Pin on shackle in mizzen sheet system worked loose. Again, if I could replace it with a soft shackle, I would.
5. We have Selden single-line slab-reefing with cars inside the boom. Before crossing the Atlantic I replaced the lines. When I took the end-cap off the boom, I discovered that on both reef 1 and 2, the shackles that secured the end of the line had worked loose and were not even finger-tight any more. When I reassembled, I lockwired them.
6. I discovered stress cracks at the weak point on the jaw on both of the snapshackles on our 2 spinnaker halyards, so I replaced them with new ones.
During a very squally Atlantic crossing in December, we were wing-on-wing in 40kts. We suddenly got hit with 55kts from the side which got in front of the poled-out genoa, broke the pole end casting, and bent the pole in half. (See pictures). The soft-shackle holding the topping lift to the pole is still in service today.
Pole end casting: https://www.flickr.com/gp/charlieandhelen/28772Z
Pole bent in half:
