Stork_III
Have never been in a Shipwinkel-- not sure I want to either
Don't knock it until you have tried it. https://www.josboone.nl/
ps there is a downstairs as well.
Beware when going to Jos Boone.
It's full of stuff you didn't know you needed.
Been going to Middleburgh for years & never knew the place existed !!!
If you go further inland than the Staande Mastroute you will sooner or later find a fixed bridge in your way. The main locks and bridges in the Delta region will be no problem, as most bridges have a clearance of at least 18m (or more at low tide) or can be opened (marked as BB on the charts). I would recommend the ANWB Waterkaarten app as they have all the information and charts you need, and more, for the inland waterways.Thanks Sailorman and Dan, Staande Maastroute Atlas already on the shopping list, but what if we want to go off the route?
Thanks also to MoodySabre. I'm not known for planning much in advance, but I'd sooner have an idea whether she will fit before getting within Mk. I eyeball range.
It's generally the first Dutch shop I go into, despite protests. I look round, think 'this is all a bit pricey' and walk out again.Well it is hidden away.
Last yr their fuel was the cheapest in The Netherlands we came across, if staying a while dont export too much fuel from EnglandIt's generally the first Dutch shop I go into, despite protests. I look round, think 'this is all a bit pricey' and walk out again.
Then on the way home I go in there again, and think 'Maybe it's not so expensive after all....'
Last trip we left via the roompkt and had a fantastic sail to ijmuiden wjth a varm easterly breze vismpktOpen CPN is all new to me, have to get y thinking head on to deal with new fangled ideas, but many thanks - that should be a great experience.
Yes we will be getting folios, but prefer not to fork out first, then find the boat won't fit! Perhaps 17m clearance is universal and I'm worrying unnecessarily - never had problems with 12,5m air draft on visits with previous yachts Outline plan is in at Vlissingen and work our way North to Amsterdam and as far beyond as time, weather and inclination take us. She's a shared boat, so crew (and skipper) swaps will happen, and she may be left alone on occasion. As I implied earlier, I'm not known for making detailed plans, preferring to go with the flow.
Thanks for everyone's help.
Plus cheap diesel from thejr bunkerBeware when going to Jos Boone.
