robind
Brake cleaner
Brake cleaner is also good for getting engine oil out of teak decks!
Brake cleaner
For future reference, push the tape back on the adhesive and then warm it all up well with a hot air gun, slowly remove tape and adhesive will come with it. If adhesive is left behind, replace tape and repeat hot air gun - takes time but has proven to be fool-proof - so far! ! !On my recent Atlantic crossing my new Lewmar Oecan 60 forehatch leaked, whenever water came over the foredeck. The solution I chose was to use duck tape to seal the hatch, and this worked; no more water through the hatch seals.
However the tape has peeled away leaving the tape adhesive stuck to the aluminum and gelcoat. What is the best method to remove the "goo" without damage to hatch or deck ?? Is there a wonder spary on wipe off cleaner that will work ?
Mike
de-solv-it available at Homebase
Citrus based
Removed the glue residue from "blasting tape" on the hull of my boat. Blasting tape has an adhesive which makes most duct tapes look as if they don't have any glue. Desolvit dissolved the glue in seconds with no possibility of harm to the gelcoat.
