Dual battery charging and common negative
Gixer
29 Nov 2015
Hey all,
I think I’m going to fit a dual feed 240v charger (Sterling Pro Sport) for my domestic and engine battery. Just realised the batteries have a common negative at the isolator and was wondering if this will affect the chargers ’brain’.
I was planning to attach the engine battery terminals directly to one feed of the charger and on the domestic side, the other feeds positive to the battery and negative to the load side of the battery monitor shunt.
If there’s a better way to be this I’m all ears ?
The common negative shouldn't affect anything. The dual feed ProSport charger is unusual in having a pos & neg wire for each output, but it shouldn't be a problem.
Thanks for the responses guys, as usual I was overthinking it ?
BabaYaga, no I have a standard 1,2 both switch on the live but another separate isolator on the negative.
Funnily enough Alan it did fail recently and I replaced it with a new one.
It will come out along with the 1,2 both switch soon but I’m desperate to get back it the water so that can wait.
Paint the negative isolator yellow and use it as the emergency switch. when you take the 1-2-B out.
