l'escargot
It seems pretty obvious that this is the case.
But not as stupid as someone who quotes another post supporting my view whilst trying to argue against it though...
An O/D incident is normally triggered by a call to CG - worried relative, trailer and car found on a slipway, missed berthing arrival when departure was known, etc. To be made as a broadcast the first steps - telephone contacts, shore contacts, etc would have been done.
Having a passage plan would tell us where to start the search, the likely course of the boat, which bx aerials stand the best first chance, etc. It also enables us to construct a backtrack search pattern.
Of course, if you're l'escargot, all of this is rubbish and I don't know what I'm talking about.
But you do have a history of not knowing what you are talking about on a wide range of subjects don't you. How long since you worked as a coastguard?
None but then I'm not claiming any expertise - unlike you... If you don'like being on the receiving end, best not to set out to be offensive yourself.You really are an offensive little oik aren't you?
I left last year - and still have involvement in what's going on currently.
Remind me how many SAR incidents you've coordinated?
My CG66 documentation pack which was issued by the Coast Guard just over a year ago recognised the value of logging a passage plan under the appropriate circumstances.
Your argument started to fall apart when you had to agree that it wasn't policy to implement searches based on passage plans, which was the original discussion before you meandered off in other directions.
:encouragement:You really are an offensive little oik aren't you?
...the passage plan is not designed to trigger an overdue search...
And I'll continue to disagree - a passage plan that won't be looked at offers no security and still looks like a waste of time to me. It is only as good as the shore contact, an unreliable one is a waste of time too, a reliable one will have an updated plan and actually cause a search to be initiated - a far better outcome. Perhaps I'll stick my own rider on for the hard of understanding - they are a waste of time without a reliable shore contact. How's that?...If you don't want to file one, fine - I couldn't care less. But there are people that do not have reliable shore contacts, or like the security of filing a plan, or who simply wish to do so - and it is wrong to say that they are wasting their time.
And in that respect is a waste of time...
I think this person is arguing about something he/she does not understand.
Rather than reading the posts and learning he tends to get offensive with others.
Watch his response, I'll be the next to be called ignorant or lacking knowledge.
My only response is that you clearly haven't read or don't understand my early posts on this thread. Your response is based on what others have said and you even drop in your own little straw man. I notice you also creep in the little "or responsible person' rider - if you do actually bother to read what I have said instead of trying to use your post as a platform to demonstrate your "expertise", you will see that is what I've actually said right from the start. You can't get away from the fact that the CG won't even look at a passage plan unless someone else tells them to...I think this person is arguing about something he/she does not understand.
It's quite simple. If a passage plan has been left ashore, either with HM Coastguard or a responsible person then any search following a report that a boat is overdue has a head start.
In the same way as a description of the boat, crew, range equipment etc will help..
No one has ever suggested that following a leaving a passage plan with the CG and then not reporting in would result in a search.
I'm also a retired CG Officer and I can assure you that when looking for a 'missing' boat having an idea of which way it went is a tremendous help.
I certainly don't feel threatened or victimised but I see a few people who feel their perceived "expertise" threatened because my viewpoint is different from theirs...That is his standard approach on many topics - he seems to feel threatened and victimised much of the time.
..."I wish everyone would contact us as diligently when they arrive", he said...
Again, you have not bothered to read my posts before responding. What would you rather have, an updated passage plan given to you by the person reporting the overdue boat or an outdated one given to you at the commencement of the voyage? What you must try to understand is the former is of more value and will initiate a search and the latter is going to waste your time...I'm certainly not suggesting HM look at passage plan in normal routine. They are kept on file (also recorded) and referred such they be needed.
What you must try to understand is the value to the CG of having a passage plan when a boats is 'overdue'.
Both I and the other person who has worked with overdue boats has pointed this out to you.
Filing passage plans either with a responsible person or HMCG is clearly not a waste of time.
You're very welcome to question anything I say on prisons, I'll be the first to say my knowledge isn't current and probably out of date, I know things change. If you can give sound arguments why the systems don't work though I'll probably agree with you - in fact I probably would be one jump ahead of you and be leading the argument. Sorry if you don't like to have your opinions questioned but that's life, I would have thought you have been around forums long enough to know that.Right, for the last time -
Not everyone has such a shore contact. Some people are single, sail on their own, don't carry a mobile phone / VHF to update changes, etc. We are after all dealing with the real world.
Let me give you an incident narrative (a real one) to illustrate. A regular of ours on my old patch sailed, single handed, a trailer sailer, from one of two or three regular points of departure. He always filed a plan. About 1930 one night we had a call from the local pub, his car was still by the slipway and they new he rarely sailed in the dark. Quick check of passage plans from that port that day found his, ETR was 1600. We did a local broadcast for info from other vessels, ran a backtrack SARIS plot from hourly intervals as we knew where his lunch destination was planned (from his plan), and tasked the local LB to run back along the line. They did that, found him halfway with a broken mast.
Now think of a similar situation where all we have is a car on a slipway, no known plan, no ETR, nada. Makes finding the o/due a bit harder, yes?
If you are in contact with shore contacts to update your plan, your way of thinking works. No problem with that. But it doesn't work for everyone, so therefore it's not a waste of time for those in that position.
You're a former PO I believe. I wouldn't question your experience of how prisons run or what your processes were and the values they have in doing them - please don't question others' experience in their professional fields when they tell you how their systems work.
