Drying out problem
peterb
16 May 2001
Radlett, Herts
Pages 28-9 of the May issue of PBO have a very good article on drying out alongside a wall. It goes into many of the problems that can arise, but misses out the one that caused us a very sleepless night.
The yacht: a Najad 380 - displacement 9 tonnes, ballast 3.1 tonnes in a massive lead casting forming the fin keel. The place: Gorey harbour, Jersey. No big problem, we'd dried out there before, though not in the Najad. But the Najad was very sturdily built; what could go wrong?
We put the boat alongside, port side to, carefully positioned in respect of the harbour ladder. We laid out our anchor chain along the deck, so that she was heeled towards the wall. We had a fender board, with six fat fenders. We took the halyard across to a strong point on the wall, and settled down to watch her dry out.
At 1900, as calculated, she duly touched. We felt that stiffening, the loss of those small movements that show that she's still afloat. We waited for her to lean against the wall and for the fenders to take up their load.
Except, they didn't. As the tide dropped she inexorably leant outwards. We took warps from our strong points (winches and cleats) on the port side, underneath the boat and up to strong points on the harbour wall. The halyard came under such strain that we worried about breaking it, so we slackened it a little. In the end, after an hour or so, but with our inclinometer showing seven degrees of outward heel, she seemed to settle down.
Sleeping on a boat like that gives one a very uncomfortable feeling, with an easy solution; you don't. We waited until she had dried out, then went down to see what had happened.
The answer turned out to be simple; she was a Scandinavian (Swedish) boat. That bit of the Baltic gets virtually no tidal rise and fall, so Scandinavian sailors can't put their boats alongside a wall and dry out. Our massive lead keel casting had a totally flat bottom; put it down on to firm Gorey sand and the boat wants to sit on that flat bottom. If the sand happens to slope at seven degrees, then the boat will want to heel at seven degrees, and it's difficult to argue with three tonnes of lead.
The Najad has a particularly wide keel. With a narrower keel we might have held the boat vertical, or even sunk an inch or two into the sand. If the bottom of the keel had been veed or curved then it would have been OK. But I still wonder what would have happened if the sand had sloped at, say, ten degrees? How much slope would have been needed for the boat to fall outwards?
Look first
I always likes to look at the ground at low water on the tide before I dry out.. Mostly because I am a bit of an old woman over these things... what was not there last year is not necessarily not there this year..
Careful what you attach the halyard to - a rather nice Westerly next to us was in for repair, having fallen over after (according to owner) attaching their halyard to a dinghy rack on shore. Ouch! Probably looked solid enough at the time...
The mass of the vessel acts down through the centre of gravity. With a balanced boat it is in the centre line. The bouyancy of the vessel acts upwards through the centre of buoyancy; the centroid of the immersed volume and again on the centre line all things being equal. Once the vessel takes the ground the sea bed provides the upward thrust to counter the mass. All things remain in line. Begin to heel over, either due to the sea bed or weight distribution the vessel will remain upright until the line of the mass acting down moves out side of the contact area acting up. The two forces then act as a couple to make it fall over. Most probably slip first, then......
