What do you mean by "also"?If you can't get a Radice to fit (the diameter of tubes they fit is limited) then consider a Tides Marine, also a lip seal design
If you are sure that the shaft is 35mm, 80mm would be way too large for the stern tube, let alone 90.Shaft is 35mm. Not too sure of stern tube size until I get down to the boat at the W/end. Looks to be 80-90mm from the photo. So I may not be able to use the Radice.
Radice is a lip seal (2 in fact inside the moulded body). Personally i don't like face seals in this application. They are fine if the shaft does not move, but boat shafts do - fore and aft and side to side. There was an excellent article in PBO a couple of months ago describing failure of a PSS following an incident when the boat was put hard in reverse with the rudder over. The force of the water pushed the shaft enough to open the faces and water rushed in. They do not like being left without moving in the water as the faces can stick with deposits from saltwater. Cases in the states of boats sinking because the engine was used without checking that the faces were free and the force enough to rip the bellows. Note that the DSS you have is fitted with an emergency clamp for use when the bellows fail. Why would you need that?What do you mean by "also"?
All the seals mentioned so far, bar none, work with face, not lip seals: Radice, PSS, Fluiten - even the dreaded DSS.
Tides Marine went for lip seal instead, and personally I don't like the concept of seals relying on the shaft surface friction.
That said, Tides Marine seals do have a decent reputation, and are certainly a better choice compared to the DSS.
Then again, I'd rather have stuffing boxes (and I did, in fact - for 17 troublefree years!) than the DSS...![]()
These I cannot recommend. See cautionary tale here Stern glandsIf you can't get a Radice to fit (the diameter of tubes they fit is limited) then consider a Tides Marine, also a lip seal design shaft-seals.co.uk
No, it isn't.Radice is a lip seal
Sorry. we are at cross purposes here. I was referring to the Radice/Volvo lip seals, which are what is relevant to the OP's boat as a replacement for his Deep Sea Seal, not about seals for large shafts and high powered boats. In the sailing boat and small power market lip seals dominate in the relatively few new boats built with shaft drive rather than saildrives or sterndrives - at least in Europe. Fitted by the two major builders that still use shaft drives for yachts and smaller power boatsNo, it isn't.
Radice has two types of shaft seals.
Their mainstream seal is pretty similar to the PSS in terms of design, and is available in the 45 to 105mm shaft size.
The one I think you are referring to is (according to the builder) strictly meant as a stuffing box replacement, it's only available for shafts up to 40mm, it's rated for 30kts max, and requires periodic greasing.
Which on top of being annoying, tells you a lot about how dependable the sealing actually is.
In short, there's no place for that in my boat, though if you're happy to have it on yours, that's fine with me of course!
Radice aside, ref. lip vs. face seals in general, well, let's have a look at what the industry has to offer.
After all, you would expect that in the superyacht league neither the builders nor the buyers would accept anything but the best components.
Now, the best lip seals I am aware of are those made by Tides, which are available for pretty large shafts - up to 160mm, according to their website.
But, PSS face seals are available for even larger shafts, up to 8" diameter.
And the Fluiten I previously mentioned (which you might have never heard of, because mostly meant for commercial vessels, but they are also face seals anyway) are available for shafts up to 300mm, no less.
They have no rubber bellows at all BTW, so the risk you mentioned for the PSS simply doesn't exist.
That's what I have on my current boat.
