Neeves
I want to drill 15mm aluminium plate to produce a 20mm - 25mm diameter hole. Later I might want to drill stainless or steel. I have a large and powerful variable speed bench drill but it has a limited chuck size of 12/13mm.
I know nothing about the terminology of describing drill bits and I know even less about drill bits themselves!
My drill bits are maximum of 15mm and my larger drill bits have a 'stepped' design, the portion held in the chuck is of a smaller diameter then the working part of the drill. My drill bits are simple, cheap, steel, no coatings.
What do I need to search for to source to drill 20/25mm. Do I need 'special' bits, fancy coatings. What is the term for the stepped bit (with the portion held in the chuck smaller than the bit itself (or do I need a bigger chuck).
Or is my objective inaccessible.
Jonathan
Jonathan
