jimi
I want to drill a hole in my toerail to put a block on for a spinnaker guy, is it just simply a case of drilling the hole and thats it, or is there more to it?
If your boat is similar to my Jeanneau 35, which also has a non-slotted toerail, it is held in place not by the "traditional" row of through-bolts, but by large self-tapping screws, plus sikaflex-type sealant. The function of the self-tapping screws (large x-head) seems primarily to hold down the alloy while the sikaflex sets.I want to drill a hole in my toerail to put a block on for a spinnaker guy, is it just simply a case of drilling the hole and thats it, or is there more to it?
If your boat is similar to my Jeanneau, with a non-slotted toerail, it is held in place not by the "traditional" row of through-bolts, but by large self-tapping screws, plus sealant. The only things through-bolted are the pulpit, pushpit and stanchion bases, each of which are held down by an approx 8mm machine screw thread. These non-slotted toerails are clearly not designed to support upward loads such as from a spinnaker guy.
My blocks have Velcro straps. Even cheaper.
I'm thinking I might use the chain plate for the shrouds instead and see how I get on with that.
spinlock used to sell soft eye webbing shackles, all my toerail blocks have these as no damage,unlike a snap shackle
UDHPE is easy enough to find in the US but I've not been able to source any in Europe.
Yep definitely soft eye of some sort, even if its a loop of rope.
why not a line with a block from the chain plate, you can then adjust the lead as well
