Tacking up a narrow channel. I've just tacked onto s'tbd. Pulling in the genoa sheet, the braided cover on the (rather worn) sheet breaks as the sail is almost in.
There is only one block on the toerail with a now damaged sheet running thro' it and I have to tack back to port or run aground. So I tack, and the braided cover concertina's and jams in the now windward block. Can't haul in the sail properly.
What would you do?
What would you do?
