DP leg and old antifouling
Sailorsam101
30 Dec 2004
Afternoon all.
So as the heatwave finally arrives I've decided to lift her out and work on the legs!!!
What i have is a pair of DP-e's with years of old anti fouling paint on them. It's thick or thin or still good or cracked and crazed.
So it's coming off the best i can.
I've had a go taking it off with a wire brush on a drill and that works well. But any other ideas other than elbow grease?
Obviously i need to get it done as soon as possible so i can go back into the water the day the heat wave ends!
If you used a steel brush, drill or by hand, it can leave metal particals embedded in alloy.Will rust and leave unsightly staining.
Best to use brush with brass bristles
