Tommyrot
Tommyrot: They WILL post a record. If they do not kill the cart or driver. But it will not prove that the energy,friction,wind relative to the ground explanation is valid. In the same way it will not prove my explanation. However, if they were to measure the wind speed at 1 prop diameter in front of the prop then it would disprove the treadmill analogy.
The only thing I am struggling to understand here is, are you saying that the machine doesn't work, or that it does work (You say "They will post a record"), but you need mathematical proof rather than physical proof?
I think there are different arguments going on at the same time here. Firstly, some, Shaunksb for instance, are convinced the whole thing is a scam, others believe it works.
The second argument is the explanation for how it works. I'm less interested in this, there are lots of things I use every day that I have little understanding of, but I have more important things to spend my time on than trying to learn "everything".
