RAI
Now you're joking. OK as long as you keep shoving though.Yes if there is a wind blowing. I was responding to Woodlouse's comment about it working in zero wind. I think in that situation it should work with a shove.
Won't work in zero wind. If you give it a shove, from the moment you stop pushing it'll start slowing down from drag and friction.
Snowleopards drawings are wrong, as the whole point of this discussion is to show motion in the same direction as the true wind, where as the diagram shows a broad reach in relation to true wind and motion.
Except for that whopping great propellor turning around, which will keep driving it forward. And since UG tells us that the shaft work required to turn the prop is less than the thrust you get out if it, it should keep going.Won't work in zero wind. If you give it a shove, from the moment you stop pushing it'll start slowing down from drag and friction.
What I'm saying is that once you exceed the true wind speed, whilst running dead down wind, the force that has initially pushed the cart has stopped acting upon it, which means that the energy is coming from somewhere else.
So I'll try again, the wheels are turning the propeller, which then pushes the cart that turns the wheels
I'll confess I was very much in the No camp, but then started to waver.
Ignoring the mathe, which is beyond me, those videos clearly show it working. The "how it works" bit is still a bit confusing but then so is nuclear physics.
I don't need to know how something works to accept that it does.
The movement forward rotates the wheels which turns the prop - which pushes air backwards - but you've still got air coming forwards - so you're effectively creating a mini high pressure behind the cart and it's this cushion of air/high pressure that pushes the cart onwards ....
Strictly, like a sail, it's the higher pressure behind the blade and lower pressure in front but - yes, correct. All this talk about moving in still air is just as silly as the proponents intend it to be.The movement forward rotates the wheels which turns the prop - which pushes air backwards - but you've still got air coming forwards - so you're effectively creating a mini high pressure behind the cart and it's this cushion of air/high pressure that pushes the cart onwards ....
Take away the true wind and the truck will stop ...
But it works, up to about 3 times wind speed DDWFTTW.This is priceless!
The wheels turn the propeller, allowing the wind to push the propeller, and thereby push the cart and turn the wheels.
I never seen it summed up in such a distinct way.
That sentence describes it perfectly in a nutshell. Excellent!
Yes.......................I can imagine
What limits it to "about 3 times wind speed"?
