Double balls!
Sgroves
13 Feb 2003
Nottingham united Kingdom
and while I'm at it, here's a really wierd one! in a controlled and carefully documented scientific experiment, I calculated that I needed two cork balls to support my boat/car keys, (actually, I put two on at once and bunged em in the pond to see if they'd float!) however, when they spontaneously hurled themselves from my zipped pocket into the marina this weekend, they sunk without trace. This raises a second issue, has anyone ever actually recovered anything with a sea searcher magnet?
Steve
oldgit
6 Nov 2001
Medway
your balls were obviously not BIG enough.........
<hr width=100% size=1>My little Princess/forums/images/icons/laugh.gifthe 33 of course.
kingfisher
7 Nov 2001
Belgium, Holland
Speaker magnet
We used the magnet we stripped from a 100W speaker to go dredging. We did find the sunken object.
Mind you, it was for a 2ft by 2 ft steel plate rudder, so a bunch of keys could be somewhat of a challenge.
"OK, secure rudder first, than remove retaining pin. Sounds logical"
<hr width=100% size=1>Group of people on the pontoon: skipper is the one with the toolbox.
http://sirocco31.tripod.com
paulineb
I no longer live in Hope
Could it be because the pond is freshwater and the marina is sea water - or am I being silly again?
<hr width=100% size=1>Pxx
<A target="_blank" HREF=http://www.paulinebeddoes.co.uk/php-cgi/gallery>The Perils of Pauline in Pics</A>
MedDreamer
10 Sep 2002
I think they should float better on saltwater as it is more bouyant - what a boring git I am turning into, I'll be doing pub quizes next!
<hr width=100% size=1>Martyn
byron
RIP
UK -Berks
<font color=blue> Apply the following formula and your keys will not sink. It is quite simple but don't forget that the crucial effect is that of Kim's crutchpiece on his Y fronts.
1.    Define basic scientific vocabulary:  fluid, pressure, Pascal, buoyancy,
    density, airfoil, life, thrust, drag, vacuum.
2.    List the following units of measurement:
        1 atm = 100 000 Pa
        Pressure increases 100 000 Pa / 10m water depth
3.    Apply the following mathematical formulas:
        p = f/A
        d = m/v
4.    Explain how hydraulic brakes work.
5.    Assess the concept of buoyancy by:
        a) if object's weight > buoyant force, then the object sinks; and
        b) buoyant force = weight of fluid displaced (Archimedes Principle).
6.    Explain that weight of fluid displaced depends on volume of object
    submerged.
7.    Predict that if an object's density > fluid's density, then the object sinks.
<hr width=100% size=1>http://www.alexander-advertising.co.uk
oldgit
6 Nov 2001
Medway
You bin at the turps again Mr B.
jon_bailey
3 Feb 2002
Teignmouth, Devon
www.cerberusstorage.co.uk
I've seen a set of BMW car keys recovered with a sea searcher in less than 5 mins. These did not have floats attached and this could be your problem. Sinking slowly at near neutral buoyancy could have allowed them to drift and/or flutter some way.
