dulls
N/A
Sorry when did i say dont set the anchor? Read post properlyJust to add to my last posting to make my point Dulls .We are anchored on the south of France , every day these day power cabin cruisers boats come out of the marina for the day , they turn up around 10sh drop a load of chain and jump in and swim / sun bath have lunch , around early after noon the wind start to pick up a bit every day boat dragging , you think they would learn but the next day the same boat do the same again and they drag again ,
There only one way to anchor , set the anchor .
Bottom photo shows no tension on the anchor which appears not to be set either.Dulls, I think you are describing a situation similar to that pictured below. In this case even though the Rocna is facing the wrong way it still providing the majority of the holding power. It takes a reasonable amount of force on the anchor before it starts rotating:
There are some times such as the photo below where the chain is providing all the holding power, but unless the chain is stuck under a rock or in heavy weed this will only occur if the wind is light:
The chain on its own only has very slight holding power. The chain does assist the anchors holding ability in some circumstances primarily by modifying the direction of pull, and helping the initial setting of the anchor, but this it is still the anchor probiding the holding power even when this occurs.
