halcyon
I asked the Berthon to have a look at it.
Split charge diode has gone pffft. So the charger is only «*finding*» the starter batteries.
New diode on the way.
Said diode in #2
Brian
Depends on charger design, some have one output which split via three diode to give you three outputs, one diode may have blown feeding domestic battery output.
Brian
Good idea to get this sorted ASAP.
BTW what has the split diode got to do with the Sterling Charger, which has 3 independent outputs?
Said diode in #2
Brian
I'd personally suggest switching to a quality VSR such as Victron.
Noted. On the winter refit list!
The split charge diode shouldn't be for the mains charger, it should be for the alternator. But if you do need one, I've got a used one on the van you can have for nothing.
Most chargers are single output with either a split charge or separate diodes internally to feed the different outputs so I assume it's the internal one referred to.
Yes, it has three outputs. The two outputs to the two starter batteries were fine; the output to the domestic battery was not charging at all. I asked the yard to check thinking I might have inadvertently displaced a wire. They rang back and said that a diode in the charger had, most unusually in their experience, failed and should be replaced; they said they could get one tomorrow at a cost of about £100. I asked them to go ahead. I hope this clarifies things.
In post 2 you said an internal diode inside the charger, that's not what has been diagnosed by Berthon.
