Redwing228
It could be worn seals on the crankshaft, drawing in air when warm, or the roller bearings could be shot causing too much movement around the seals. They are easy to dismantle, undo head bolts, lift off flat head, then undo bolts securing the cylinder block. Lift block up leaving the pistons behind. You can then turn engine over using the pistons to feel for any roughness, should be nice and smooth. p.s. the crankshaft is pressed together so its either a return to dolphin job or specialist in two strokes.
+1
We have had this problem with marine two-strokes. Stuarts were particularly susceptible to the point that they would peter out and stop when hot, accompanied by a lot of spitting back through the carb. The solution was to fit proper lip seals to the crank journals in place of the original bronze ring seals.
![IMG_20150821_151947022_HDR[1].jpg IMG_20150821_151947022_HDR[1].jpg](https://ybw-data.community.forum/attachments/13/13070-bc0de70d831da0de54d6cf3e36625981.jpg?hash=vA3nDYMdoN)
![IMG_20150821_152138218_HDR[1].jpg IMG_20150821_152138218_HDR[1].jpg](https://ybw-data.community.forum/attachments/13/13077-14f6bb1c7cf8af69775bc19a22c00eb5.jpg?hash=FPa7HHz4r2)
