Does unopened Sikaflex go off?
Yes, 3M 5200, and arbothane 1240 both have longer shelf lives.
I was told that's why they preffered to stock 3M in Trinidad as the heat made Sika go off quicker, seeing as it goes off with moisture the wet wetaher here could be worse.
I thought you had packed your bags and gone?
[/ QUOTE ] No, I have merely left the Lounge . . . sorry to disappoint /forums/images/graemlins/smile.gif
- W
I've used an unopened cartridge well past it's use-by date (a good year past) and it seemed to work fine. It wasn't in a highly-stressed application though - more of a sealing job.
[/ QUOTE ] This is just to seal one of the anode bolts through the hull. Not highly stressed - but I will be if it doesn't work!!
- W
Not very relevant to folk in Scotland in winter time, but the bottom shelf of my fridge is full of various opened tubes of glue and sealant - I keep unstarted ones there as well, after buying a brand new tube of 5200, and some (considerable admittedly) time later finding that it had gone solid.
Keeping the stuff cool does seem to improve the shelf life.
Just been sold a tube by the yard - 'best before Sept 2007'
- W
Hope it was cheap then!!
/forums/images/graemlins/grin.gif
Old tubes of Sikaflex go solid and there's no chance of getting the stuff out of the tube let alone do anything useful with it. Apart from covering yourself with the sticky goo.
When I pointed out that the stock was 1 month out of date, the chandleryremoved the stock and said he wouldn't stock it again and advides Arbocol(?). Says Sika goes off very quickly after the sellby date.
I just used some today the sausage type,been in the locker for years,"use by oct 2005"it seemed ok nice and flexible and soft,it was used to bed some screws in,i have 4 more in the locker all with the same date.
]....are you sure you want to use an out of date sealant on a thru hull bolt, if it leaks you will be very pissed
[/ QUOTE ] You are of course right, and I have bought an in-date tube.
Avoidable through-hull leaks should definitely be avoided . . .
- Nick
I keep sika in the freezer - never had a tube set yet
Second that - I keep all my sealants in the freezer. They all seem to last forever, silicones as well, even part used tubes. Not seen any deteriation in performance either after warming up.
