thinwater
Most of the fuel experts warn about 'yellow metals' i.e. copper and brass.
I've not seen anything authorititive about lead or tin.
But these days lead is pretty much ruled out of most things by ROSHH.
(US Automaker Trade Group Study)
"Galvanized storage tanks, piping and terne coated vehicle tanks have led to serious field issues in the past. Zinc has a tendency to accumulate in spray-holes and contribute to nozzle coking. Lead (a component of terne plating) is attacked by fuel acids and forms soap precipitates. Copper may catalytically accelerate fuel oxidation and promote deposition of solids. Non-ferrous metals and their alloys should be excluded from use in fuel pipes and storage tanks and in the entire vehicle fuel system."
(UD DOE study)
Certain metals may affect the biodiesel by accelerat-ing its oxidation process and creating fuel insolubles. Lead, tin, brass, bronze, and zinc significantly increase sediment formation in both B100 and B20. Galvanized metal and terne-coated sheet metal are not compatible with biodiesel at any blend level.
ASTM D975 Appendix X2.7.2: Fuel Storage Conditions
Copper and copper-containing alloys should be avoided. Copper can promote fuel degradation and may produce mercaptide gels. Zinc coatings can react with water or organic acids to form gels which rapidly clog filters.
Terne plating used to be lead with a little tin. Now there are many version, the most common of which is 50% zinc, which is known to be a problem.
Not mentioned in the study is that terne is vulnerable if the diesel gets even a little bug and the pH drops. I've seen severe damage to infected terne plated tanks.
There are also studies of alternative tanks materials for cars and trucks. Most of them are plastic these days. My last two boats had plastic installed tanks. Seems weird, since OSHA prohibits plastic jerry cans, but there it is.
